Announcements
AutoCAD LT 2023 - Projection Issue
g.kocRPKH5
g.kocRPKH5
Hello AutoCad users,
I'm importing an 3D drawing from an online tool to AutoCAD LT 2023. Normally, when the online tool converts the 3D drawing into a .dwg file, everyting is "projected" on a 2D space without taking the slope into consideration, hence a Topview. Roughly speaking:
will look like this:
long story short, by default the AutoCAD UCS allows me to look at it from the top without projecting it (no cos(24°) involved)
I think I have unknowingly changed something in UCS settings because what I see is that the components in Y-axis is factored with cos(24°). Could you please help me with this issue? Thanks in advance
[ The subject line of this post has been edited for clarity by @handjonathan Original: Projection Issue ]
cheryl.buck
Autodesk Support
Autodesk Support
Hi @g.kocRPKH5,
Thank you for posting. Can you provide the DWG, the program it came from and the version of AutoCAD you are working in to help the Community Members troubleshoot the issue?
All the best.
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
g.kocRPKH5
Hi!
Thank you for your reply.
  • The online tool that generates the 3D models is called SolarProTool.
  • I use AutoCAD LT 2023
    • A colleage checked the same .dwg file on AutoCAD 2022 and 2021 and on those versions it works without a problem.
pendean
Community Legend
Community Legend
The 'other' two dimensions follow the slope of the panel (PLAN command setting matched UCS command setting when they were created).
Your dimension is out there floating, and does not follow the slope at all. UCS and PLAN are set to WORLD (flat plane).
Nothing to do with being in LT or AutoCAD from what I can tell.  What else did your colleagues do that you did not? Worth watching them do it yourself.
g.kocRPKH5
@pendean Thank you for your reply. The colleague who doesn't have the issue did not make any change. We checked his and my UCS and View settings and nothing seems to be different.
You wrote "The 'other' two dimensions follow the slope of the panel (PLAN command setting matched UCS command setting when they were created)."How can I set a default setting for my PLAN to match my UCS? I just opened the file and wrote PLAN on the console, then chose UCS and nothing changes. The only fix I found is clicking the "3 Point" in Coordinates panel, then setting the positive X on the length and positive Y on the width of one of the orange rectangles and than it works. The thing is I don't want to do this manually every time I do a design.
Also, may I ask how did you get the 3D view of the drawing? Thanks a lot.
g.kocRPKH5
Dear @pendean and @cheryl.buck ,
It seems that the issue is that the UCS setting with which the file was generated is overrode by my UCS setting. Is there a way to deactivate that? Thanks in advance!
pendean
Community Legend
Community Legend
You are in total control my friend
Turn on NEA as a running Osnap, click here and follow the prompts
Now all of your dimensions work fine
HTH
