AutoCAD LT 2023 - Parts of drawing disappears at the bottom of screen
elberse
elberse
Community Visitor
Community Visitor
Since Autocad 2023, the drawing at the bottom disappears in a white bar (see attachment)
Can this be solved?
[ The subject line of this post has been edited for clarity by @handjonathan Original: drawing disappears at the bottom ]
pendean
Community Legend
Community Legend
Have you installed the 2023.1.1 Update yet? ABOUT command will confirm what you have installed. If not, get it from your Autodesk Account Page here https://manage.autodesk.com/cep/#products-services/updates
Restart your PC afterwards.
If that did not help... Set GFXDX12 variable to 0 (that's a zero) then restart AutoCAD.
Also consider turning off LINESMOOTHING and LINEFADING variables: if still no relief then start GRAPHICSCONFIG command and change the 2D Display Settings pulldown from "advanced mode" to one of the other choices.
If all else fails, then turn off Hardware Acceleration as a last resort, and start a support ticket through your subscription portal as explained here https://knowledge.autodesk.com/customer-service/account-management/users-software/support-options#:~....
dany_rochefort
@elberse  Right click on your graphics performance button and make sure you 2D display settings are set to advanced.  Check the Details tab also to make sure Smooth line display is checked. Hardware Acceleration On...
handjonathan
Hi @elberse
Thanks a lot for posting your question to the forums!   Have the solutions suggested by @dany_rochefort & @pendean helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
