AutoCAD LT 2023 - Custom Plot Scale
RPanicoAWJND
Observer Observer
Message 2 of 9
RPanicoAWJND
Observer
Observer
AutoCAD 2023 LT, Custom plot scale is not working and "Apply to Layout" tab is always greyed out?
[ The subject line of this post has been edited for clarity by @handjonathan Original: Custom Plot Scale ]
Replies (8)
Message 1 of 9
RPanicoAWJND
Observer
Observer
I am using AutoCAD LT 2023, Custom Plot Scale is not working, "Apply to Layout" tab is always Greyed out?
Message 3 of 9
pendean
Community Legend
Community Legend
Not working? Can you be more specific?
OR...
Can you share screenshots of where you are trying to do all of that in LT2023 please?
Message 4 of 9
RPanicoAWJND
Observer
Observer
i have plot scale set to custom, when i change the scale it wont take the change and i cannot press the "APPLY" tab because it is greyed out and cannot be pressed. Used to be that when i made a scale change i would just press the "Apply" tab for the change to take place.
Message 5 of 9
RPanicoAWJND
Observer
Observer
Message 6 of 9
RobDraw
Are you in a layout?
Sorry, needs to be asked.
Rob
Message 7 of 9
pendean
Community Legend
Community Legend
Wondering why you left this empty, do you not know if you need inches or mm? If you don't know, AutoCAD is not going to know either.
And why are you using CutePDF if I may ask? Maybe it is the problem too, none of us over here can support you using that 3rd party driver, you'll need to go ask CutePDF Support for help.
Message 8 of 9
RPanicoAWJND
Observer
Observer
There are no units to select. this hall happens no matter which PDF driver i choose or printer for that matter.
Message 9 of 9
pendean
Community Legend
Community Legend
@RPanicoAWJND This happens in ALL DWG files? Even if you start a new one?
Then you'll need to reinstall your software then and this time avoid any migration options.
If the problem is just this file, then INSERT this one file into an empty file, EXPLODE that insertion, SAVEAS to create a new file, and start over.
LT2023 plotting works fine in our office for everyone using it.
