Hi, I am trying to find my hatch pattern folder
There is no special hatch pattern folder, all reachable folders are valid.
in autocad lt 2022 to add a custom hatch.
I prefer to use Your own locations to add custom stuff!
d:\CAD\patlin\<your folder for *.pat files> for example
This way you don't need to move the folder for new versions, just add this path as Support file search path
Command: OPTIONS [F1]
When I search .pat files one comes up, and says that that the location is UserDataCache/en-US/Support,
NO! This folder is not for your use, that's the source for new user profiles.
The standard .PAT files are here:
C:\Users\<userid>\AppData\Roaming\Autodesk\AutoCAD LT 20nn\Rnn\<lan>\Support\
ACAD.pat and ACADISO.pat
>>"but when I go there I don't see the folder.
Again: This is NOT the folder you need! But... type it by hand if you have trouble with the hidden system folders
by hand, or copy&paste..
C:\Program Files\Autodesk\AutoCAD LT 2022\UserDataCache\en-Us\Support
