Whenever I use the F keys mid command, AutoCAD LT becomes unresponsive. Basically, if I enter F8 before i start a command, it works find. However, If I am in the line command and hit f8, the entire program freezes and becomes unresponsive until i click over to my other screen and then click back. Then the keyboard is unresponsive but i can cancel the command with right click. Has anybody else experienced this? And if so, what did you do to fix it?
I just updated to the Windows 10 Anniversary Update. Until then, I had no issue.
Solved by thejac. Go to Solution.
It has been mentioned several times earlier in this thread. Autodesk is aware of this issue and working on a fix. For now, the workaround is to set the variable TEMPOVERRIDES to 0.
You can also temporarily do ORTHOMODE by holding down the LEFT SHIFT key, but only as long as you are holding it down. If you set TEMPOVERRIDES to 0, it disables the LEFT SHIFT key for ORTHOMODE and fixes the F8 conflict somehow.
This issue has been known since early August, hopefully they are closing in on a fix. Last I heard a week or two ago, they said they were working with Microsoft to resolve the issue.
You would be wise not to "roll back" Windows versions for just this simple temporary problem, which has an very easy work around. Old timers still using Windows XP are giving really bad advise on here and don't realize that the newest versions of Windows have security / feature enhancements that are constantly being updated which far out way any need to go backwards for a simple problem. I'd say leave rolling back to extreme cases where your program is just unusable. OS updates are "forced on you" for your own good.
I agree, you're either damned if you do or damned if you don't. With the sophistication of hackers today, I'd rather be safe and work around an issue than make it easy for my PC to get owned. Autodesk will learn from this and get better at responding more timely (hopefully).
Thanks! I agree with that. If for nothing more than staying efficient on the job. But the notion of security also makes sense.
Certainly. That makes sense, and I agree. But, in this case, I'm not "dead in the water". TEMPOVERRIDES works for now.
What would be the motive for scare tactics? Microsoft did offer the update for free, and I willingly accepted.
This has been fixed as of AutoCAD / LT 2017.1.1 update recently released. It should either show up in Autodesk Desktop App updates, or through your Autodesk Account portal (or your admin may need to get it for you).
AutoCAD / LT 2017.1.1 Update Readme
http://up.autodesk.com/2017/ACD/AutoCAD_2017.1.1_Update_Readme_Enu.html
Hi All,
I've got a problem with a user that I haven't read about here:
We have recently (in the last two weeks) updated our system to Windows 10, and in doing so I loaded AutoCAD 2015 onto one of my users laptop.
We all had the F8 freezing problem and the TEMPOVERRIDES switch fixed the issue for all of us.
However, when he takes his laptop home and works locally, the problem re-arises (Checked TEMPOVERRIDES as being both 1 & 0). He also gets a volume bar thing come up in the top left hand corner when he presses F2. I've asked if he uses a different keyboard and he has said he does; I've asked he does a few tests with different keyboards to see if that identifies an issue.
Anybody else had this?
Please provide and update for AutoCAD 2016. I have the same issue on my machine after installing build 1703 from Microsoft Creator Update.
Dell Precession T3610
Xeon E5-1620 w/ 32 GB ram.
I have no other issues with Cad.
