Hii
i cant create shortcut command in my autocad LT 2017 tell me how it will be work
Solved by Emmsleys. Go to Solution.
Hi @emanvelm
Welcome to the AutoCAD LT forum board. It looks like this AKN article would help with your question.
If this doesn't help post back and I'll be happy to answer any other questions.
Following up on your thread, were you able to find a solution or a workaround? Did any of the posts in the thread help with the issue?
Please use the Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Thanks for your time.
Did you post your new issue on another thread?
Would you be able to elaborate more?
I'm confused by your post. Did you get your other issue resolved?
I'd be happy to help would you be able to elaborate more?
Let me know.
