I recently downloaded the newest verison of AutoCAD Inventer LT Suite 2016, the only program from this suite I have issues with is AutoCAD, Inventor opens up just fine.
After I finished the install and started up the program, i get a message that says unable to load profile file. I looked this up and found other versions have had similar problems. My problem is none of their solutions worked for me. I uninstalled/installed the program, I ran a registry cleaner, and neither worked.
Solved by pendean. Go to Solution.
