AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
AutoCad freezing when I dont use my mouce for a minute
13 REPLIES 13
Message 1 of 14
403 Views, 13 Replies
I recently installed AutoCAD 2017 onto my HP Omen laptop however when in the model space if I stop using my mouse for a minute it freezes. This only occurs in the model space and if I move my mouse out of it it reappears allowing me to select commands on the ribbon. Anyone know what may be the issue?
Thanks, David
13 REPLIES 13
Message 2 of 14
rkmcswain
So once it freezes, it unfreezes if you move the cursor outside of what? AutoCAD?
R.K. McSwain     | CADpanacea | on twitter
Message 3 of 14
in reply to: rkmcswain
It freezes in the model space when drawing. It I move outside the model space to the command ribbon the mouse returns. It allows me to select commands etc but for example when I select to draw a line it allows me select it, dimension it but I can see the line nor the mouse
Message 4 of 14
Ive attached two screenshot images on what I can see
Message 5 of 14
rkmcswain
So to make sure I understand, the crosshairs in MS are there, until you don't move them for a minute?
What you are saying almost sounds like SNAP is enabled and your screensize is smaller than the SNAP increment.
Just for a test, type in CURSORTYPE and set it to 1. Any difference?
Message 6 of 14
rkmcswain
Type in the command GRAPHICSCONFIG.
When the dialog opens, turn OFF hardware acceleration.
Close the dialog.
Any better?
Message 7 of 14
Unfortunately no difference, still froze when I didn't move the mouse for a few seconds (20secs)
Message 8 of 14
rkmcswain
Hardware acceleration is still ON in your screenshot (3) and (4)
Message 9 of 14
This seems to be working now, however, it is gone very laggy...is there a way of reducing this lag without turning on hardware acceleration completely?
Message 10 of 14
rkmcswain
Possibly. Make sure your video card is supported, and that you have the recommended driver.
Start here: http://usa.autodesk.com/adsk/servlet/syscert?siteID=123112&id=18844534
(sometimes that link requires an F5 refresh to work for me....)
Message 11 of 14
Emmsleys
It appears that several folks have tried to help on this issue. Were you able to find a solution? Or a workaround?
Did any of the posts in the thread help with your issue?
Please post back in the thread if you are still having an issue with AutoCAD LT or Select Accept as Solution for the post’s that helped.
Thanks for your time.
Sarah Emmsley
Technical Support Specialist
Message 12 of 14
in reply to: Emmsleys
Sarah,
Unfortunately, none resolved the issue, it seems to be a memory problem as it works for a while then freezes on my model space. Is there a way of getting more cache memory or moving to video memory. It also crashes with an Unhandled access violation. It couldn't be the spec of the laptop as the specs are attached.
Message 13 of 14
Emmsleys
Have you tried uninstalling/reinstalling the video driver? Or testing a universal video driver?
Sarah Emmsley
Message 14 of 14
Emmsleys
To add;
Sarah Emmsley
”Boost
