It seems that the file association for .dwg files is still pointing to the previous version of AutoCAD (2022) even after installing AutoCAD 2024. This can happen if the file association settings were not updated correctly during the installation process. Here are a few steps you can try to resolve the issue:
1. Associate .dwg Files with AutoCAD 2024: Open the Settings app in Windows and go to "Apps" or "Apps & features." Scroll down and click on "Default apps" (or "Default applications" in some versions). Under "Choose default apps," click on "Set defaults by app" or "Choose default apps by file type." Locate AutoCAD 2024 in the list of installed apps, select it, and choose "Set this program as default" or "Choose defaults for this program." This should associate .dwg files with AutoCAD 2024.
2. Use "Open With" to Set Default Program: Right-click on a .dwg file, select "Open With," and then click on "Choose another app." In the "How do you want to open this file?" window, select AutoCAD 2024 from the list of available programs, and make sure to check the box that says "Always use this app to open .dwg files." Click "OK" to save the changes. Repeat this process for any other .dwg files that are not opening with the correct version of AutoCAD.
3. Repair AutoCAD 2024 Installation: It's possible that there was an issue during the installation of AutoCAD 2024 that caused the file association problem. Try repairing the AutoCAD 2024 installation by going to "Apps" or "Apps & features" in the Windows Settings, locating AutoCAD 2024 in the list of installed apps, and selecting "Modify" or "Repair." Follow the on-screen instructions to complete the repair process. Afterward, check if the file association for .dwg files is correctly set to AutoCAD 2024.
4. Contact AutoCAD Support: If the issue persists, it would be best to reach out to AutoCAD support for further assistance. They can provide specific guidance and troubleshooting steps tailored to the AutoCAD software and its integration with file associations on your system.
By following these steps, you should be able to associate .dwg files with AutoCAD 2024 and resolve the issue of the incorrect default file path message when opening files directly from the file explorer.
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
