Loaded Autocad 2013 LT on my Lenovo W500 which has the ATI Mobility Fire GL V5700 graphics and I keep getting an Heidi Module Load Error which reads - The Confiqured heidi Driver Cannot be loaded - Switching to default software driver. This also comes up every time i open a drawing file. All the graphics seem to be off and Autocad is not acting right.
Solved by pendean. Go to Solution.
Solved by technoidatx. Go to Solution.
This may be caused by caused by the 3D accelerrartion. Type in 3Dconfig and turn it off.
Thanks, Only problem is when I do that only half of the 3dconfig screen comes up. I can only see the Update button, and a check box for the hard ware something??? it is like the resolution is off. I have it set on my computer at 1680x1050.
No not that i know of. This is window 7 Pro and this is the first time I am using it. So I will have figure out how to check and change that.
Ok, thank you. I adjusted my windows text and icon size which was set at default 150% and now things look better. For the Heidi Driver issue I turned off the 3d hardware acc. and now the error meesage is gone. Only thing left is the icons on my tool palets I made will not show up even if I change the veiw options. Any ideas>
I just installed AutoCAD LT 2013 on a Dell/AlienWare Aurora desktop just yesterday (Oct. 25, 2012), I experienced one instance of the "Heidi" error. However I have'nt noticed this error since that instance.
I went into my DirectX diagnostic's and it reads "no problems" for each parameter. I'm using an NVIDIA GeForce GTS 240 video adapter card.
Hopefully everything is good?
