AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Auto dimension?
13 REPLIES 13
Message 1 of 14
19075 Views, 13 Replies
Auto dimension?
?? Is there a command that allows you to auto dimension objects with a click of a finger?
13 REPLIES 13
Message 2 of 14
Have you looked at QDIM? -- Daniel J. Altamura, R.A. Altamura Architectural Consulting and SoftWorx, Autodesk Authorized Developer -------------------------------------------------------------------- "CadStudent" wrote in message news:6011142.1108487141089.JavaMail.jive@jiveforum2.autodesk.com... > ?? Is there a command that allows you to auto dimension objects with a > click of a finger?
Message 3 of 14
I'm sorry I cant say I have. Could you give me a easy way to find this command line and how to use the "QDIM" command?
Message 4 of 14
QDIM is not in LT, is it? -- Dean Saadallah Add-on products for LT http://www.pendean.com/lt --
Message 5 of 14
DIMLINEAR or DIMALIGNED command, hit twice and simply pick the like or Pline segment you want to dimension. Then use DIMCONTINUE command to keep running with that same dimension thread. -- Dean Saadallah Add-on products for LT http://www.pendean.com/lt --
Message 6 of 14
DOH! You are correct Sir. LT doesn't have QDIM, only full AutoCAD. My Bad. -- Daniel J. Altamura, R.A. Altamura Architectural Consulting and SoftWorx, Autodesk Authorized Developer -------------------------------------------------------------------- "Dean Saadallah" wrote in message news:42123450$1_3@newsprd01... > QDIM is not in LT, is it? > > -- > Dean Saadallah > Add-on products for LT > http://www.pendean.com/lt > -- > >
Message 7 of 14
No problem, just checking, I was feeling left out lol -- Dean Saadallah Add-on products for LT http://www.pendean.com/lt --
Message 8 of 14
Also, to pick up a dimension thread that has been started use DIMCONTINUE and pick "Select dimension to continue" and it will start where you left off.
DIMBASELINE is one to explore also.
I've seen the QDIM in operation. (Drool with Envy, gotta start saving my pennies)
Charlie
Message 9 of 14
sendocaiman
It is on the later versions. Not sure what year they started including it on LT versions.
Message 10 of 14
arpansark0544TCX
I found this Lisp which could help you out.
Link to the lisp
https://www.kimprojects.com/free-lisp-programs/#ad.
Message 11 of 14
steven-g
in reply to: arpansark0544TCX
@arpansark0544TCX
There is no Lisp in LT
Message 12 of 14
Pearson_Mhurudzekunze
Use QDIM. Now in LT
Message 13 of 14
@Pearson_Mhurudzekunze wrote:
Use QDIM. Now in LT
Now? It's been around for quite some time now https://help.autodesk.com/view/ACDLT/2015/ENU/?guid=GUID-1FB628B7-C2AF-4B6D-B83E-20ADDD70614D
Message 14 of 14
cadffm
I stumbled into this thread and remembered that I help someone a year ago:
There is not Lisp in LT up to Version LT2023, but started in Version 2024 there is an Lisp API.
Not 100% of Lisp functions are available in LT.
If  someone try to use AD (AD-Automatic Dimension Autocad.lsp) in LT2024 or newer:
In case of the linked tool "AD", it will not work in LT - but you can use it with this LT-fix
Load 'AD-Automatic Dimension Autocad' first, then  load "AD-AutomaticDimensionAutocad-LT" <click>.
The only difference to the original function in full AutoCAD: The tool can't remember what was your last used option of this command in this drawing.
Sebastian
Forma Design Contest
Technology Administrators
