Attribute Extraction Template File Error - Output File Blank
GemmaL2PS9C
GemmaL2PS9C
I am really struggling to get my head round what I am doing wrong in trying to create an attribute extraction template file.  I am following advice in the link below and still getting a blank output txt file.
https://knowledge.autodesk.com/support/autocad-lt/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/Au...
I attach the blocks I would like to extract the ref and coordinates from to form a schedule.  I have also attached the txt template file I have created.  Someone please help, it's sending me a bit crazy!
Thank you!!
cadffm
Attribute Extraction needs Attribute settings in your mask
Sebastian
GemmaL2PS9C
Thank you!!  I don't know exactly what you mean by mask but I can see the change you made in the attached file and it works now!  Thank you very much!
