Is it possible to Extract block info if the same block is in different layouts? That is, can I define a particular layout from which the attributes within a block are extracted?
The issue I'm talking about is the my Title block and all attributes (in a layout), which would only be defined by an attribute tag called dwg number, assuming of course that my layout name is the same as my dwg number...... there could be lots of the same block....
Thanks Peeps ๐
Regards
Les
