-attedit 0 found
-attedit 0 found
I'm trying to write a macro to quickly change a blocks attribute value.
when i use -attedit and select the block i get "0 found"
the attributes misc settings are all set to "no"
Any ideas? This is driving me mad Smiley Surprised
Replies (15)
cadffm
And where is your macro? I can t see it.
Sebastian
apologies, the macro is kind of irrelevant as i get the same problem doing it manually.
attedit (not -attedit) and eattedit both work fine and bring up the dialogue box when i select the block.
even if i use attedit in the macro it acts like -attedit and thus run into the same problem
the macro so far is below.:
*^C^C_attedit;_y;;;;\
cadffm
That it did not work manually I had not read out, sorry.
a) If the Attribute-Layer is locked, Acad call it in the commandline/Textwindow [F2]
    Objects on locked Layer cant be modify
b) If it isnt an Attribut (the Attributdefinition "ATTDEF" is set to constant in your Blockdefinition)
    There is no Attribut on your Blockreference to edit
Sebastian
All layers are unlocked in both the drawing and the block.
Command line shows "select attributes: 0 found" when block is selected
 Attribute constant is set to "NO" however it is grayed out on the 'edit attribute' dialogue box. see attached image
h_s_walker
Below is a snippet of code I've got in a visual basic program. Long story short it replaces the REF attribute with a number
Chr$(13) is the equivalent of enter or ; in the case of a macro and ent$ is a space. Yes I know my programming is shoddy.
"-ATTEDIT N N attriba2a" + Chr$(13) + "REF" + Chr$(13) + "REF" + Chr$(13) + "REF" + Chr$(13) + Job_Number.Text + ent$
Howard Walker
Left Handed and Proud
cadffm
And you are clicking on Attribut (not a line or a circle of Block?)
hmm.
Please Upload example file with one Blockreference, thx.
Sebastian
pendean
Community Legend
Community Legend
Shouldn't your attribute selection come right after ATTEDIT command? Type it at the commandline and see.
Otherwise Post your block with the attribute here for all of us to try it.
steven-g
The greyed out constant looks strange, and without seeing a block then I would go with CADffm's suggestion, the attedit command when used in a macro won't work by selecting just the blocks, you do have to select the actual attribute text if you are going with the one at a time option
Thanks for the responses so far.
I've attached the block to see if there's something i'm missing
pendean
Community Legend
Community Legend
Your hatch is in the way: erase it or type a longer entry so the attribute goes outside the circle and see for yourself.
THANK YOU!!
akitchensZEZPR
This was exactly my issue. Is there a workaround so that I can still use a background hatch in my block?
Making the default text longer so that it sticks out past the hatch works the first time, but once you edit the attribute, it doesn't stick out anymore, so if you need to go back and edit it a second time, you can't.
I have made sure that the draworder of the hatch is "send to back" but it is still impairing my ability to select the attribute. I can simply delete the hatch if I have to, but would love to keep it if it's possible.
cadffm
Create the objects in the order you need, try it again..
Edit block
copy hatch 0,0 0,0
Erase previous
BSave
Still an issue?
Sebastian
akitchensZEZPR
After copying then erasing the hatch, I sent it to back, then BSave.
It was still having the same problem.
Then, I changed the text style to Calibri since that has a thicker line weight. This almost worked, but you have to zoom WAYYYY close and click on the text in just the right place. Sadly, this would significantly slow down the editing process, which is no good.
Then I remembered that the background was not actually a solid hatch. It was a SOLID. I sometimes use solids for block backgrounds because it will work with the dynamic stretch function, while hatch does not. But I don't actually need the dynamic stretch function for this particular block, So I deleted that and replaced it with a solid hatch. BINGO! It works now. No need to make the default text longer or anything!
I'm not sure why the Solid was getting in the way, but if anyone else has this problem try replacing it with a hatch.
cadffm
and also if that wasn't the solution - I wrote it wrong.
Instead of hatch copy.. I mean the object(s) what should be in front.
Sebastian
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
