ArrayClassic command not found in Autocad LT 2018
Message 1 of 21
Hi
I'm referring to this article:
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/You-want...
Whenever I try to use this command, I get the message that the command is not found?
Replies (20)
Message 2 of 21
h_s_walker
If you start typing in the first few letters, does the autocomplete dialog box pop up? If it does what does it show?
Howard Walker
Left Handed and Proud
Message 3 of 21
Only the array command shows up
Message 4 of 21
h_s_walker
That is weird. A command isn't usually removed.
Can you do a screencast so we can see what's happening.
When I type AR on my machine (LT 2016)
Array is the at the top of the dialog box followed by Arraypath and then Arrayclassic.
Howard Walker
Message 5 of 21
steven-g
It's there in 2018 LT, do you have the latest updates installed? any other strange behaviour
Did you alter the pgp file as shown in your original link, because I did manage to break the command by intoducing an error in the acad.pgp file which then gives the prompt that command can't be found.
Message 6 of 21
pendean
Community Legend
Community Legend
Did you migrate from an older version when you started using LT2018? Or did you start using it as is OOTB? The command is there if I type it here too.
Message 7 of 21
This is what I get when I type array.
I didn't change any pgp files. This is also a fresh isntallation of last week.
Message 8 of 21
steven-g
No solution just a comment
It does seem odd you are not seeing arrayclassic, but you are also not seeing the other arraypath, arrayrect or arraypolar commands. These variations of array are also not available in the cui so they must be loaded differently into Autocad. Maybe you need to re-install, having said that the 3 other array options I mentioned above should actually be available from the Ribbon Home Tab on the Modify panel, or from the Menu Modify tab, do they work from there and looking at the command line what does it tell you, or are they also missing?
Message 9 of 21
Hi
I checked, they are listed in the Modify>Array tab. However, when I press them I get an unknown command error. I checked with his collegue (installation is from the same date, same version) and he has the command. I copied his AcArray files to the device with the problems. However without succes!
Message 10 of 21
pendean
Community Legend
Community Legend
Did you reset LT2018 yet? Here is how https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to...
If that did not work, did you try and reinstall LT2018? Here is how https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/How-to-reinstall-or-repa...
Doing nothing or just randomly copying files from other installations is never a solution my friend.
Message 11 of 21
steven-g
There's an English expression "if it ain't broke don't fix it" but in this case it sounds broke.
Message 12 of 21
Well I guess I'll need to reimport my toolpallettes after resetting...
Message 13 of 21
Maybe if try to type ARRAYCLASSIC, won´t appear?
Im my 2017 AutoCAd the Array command only shows in line command, then i edit the .pgp file and add a line with the key command " A " and i write " , ARRAYCLASSIC ", then the dialog box appears.
Message 14 of 21
If I would repair the installation, would I lose all my toolpallettes?
Message 15 of 21
h_s_walker
Export all your settings. Do a repair install and then import your settings
See the attached image
Howard Walker
Message 16 of 21
I repaired the installation, however the arrayclassic is still missing.
If I reinstall it and then import the settings, would I lose things?
Message 17 of 21
cadffm
If full type-in of "_.ARRAYCLASSIC" with a (new) admin windows profile isn't working..
Export incl. network located stuff and you don't loose things, store the export file far away from autodesk folders.
Please follow the Autodesk articel for clean uninstalls und clean installs.
https://knowledge.autodesk.com/customer-service/download-install/remove-products/clean-uninstall
Before you can check one thing more:
[WIN]+R
regedit
navigate to this folder and compare it with your registry:
[HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD LT\R24\ACADLT-1001\Applications\AcadArray]
"DESCRIPTION"="AcadArray Command Module"
"LOADCTRLS"=dword:0000000d
"LOADER"="C:\\Program Files\\Autodesk\\AutoCAD LT 2018\\AcArray.arx"
[HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD LT\R24\ACADLT-1001\Applications\AcadArray\Commands]
"ARRAYCLASSIC"="AcArrayRes.dll:5"
[HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD LT\R24\ACADLT-1001\Applications\AcadArray\Groups]
"ACAD_ARRAY"="ACAD_ARRAY"
Sebastian
Message 18 of 21
Thank you for the reply
I checked the registry and it's the same as yours.
Message 19 of 21
cadffm
Ok,
export all settings
clean uninstall
clean install WITHOUT any migration
TEST _.ARRAYCLASSIC
Post here
Sebastian
Message 20 of 21
Just did the reinstall and it has arrayclassic.
Should I now try to import my settings?
