Array command creates individual entities?
Something has changed in my settings when I create arrays, and I'm not sure what happened. When I go to create an array from any object what is happening is the created array is just treated as discrete objects once the command finishes. It used to leave it as an array object that would bring up the array creation ribbon if I selected it later on, allowing me to modify the array however I wanted and move the array around the screen as a group just by clicking the base point. Furthermore, it's not specific to any one document, it's doing it on new documents and even when I choose to create new documents from tutorial templates. How do I change it back?
jayhar
Can you please upload AutoCAD 2013 format.
Hint: Enter new value for ARRAYASSOCIATIVITY <1>
Jayhar
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
pendean
Community Legend
Community Legend
Show us your work: either post a DWG file or post a video of you in action using that command with this free recorder https://knowledge.autodesk.com/community/screencast
Arrayassociativity was set to zero, I set it to one like you suggested and that did the trick! Much appreciated!
