AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Annotative Text
4 REPLIES 4
MikeKovacik4928
85 Views, 4 Replies
Annotative Text
Hi All
I am trying to put annotative text into one detailed viewport (1:12.5)
However I don't want it to appear in the main viewport (1:25)
the main viewport is set at annotative scale of 1:25
the detailed viewport is set at annotative scale of 1:12.5
The text only has one annotative scale of 1:12.5 for the detailed viewport.
However it is appearing in the other viewport at half size.
I do not understand this, it should not appear at all in that viewport.
What am I missing here. Is there another setting I have missed or something else
I haven't done.
I am guessing this is indeed possible with text as with dimensions.
The dimensions are working perfectly, no problems there.
Michael Kovacik
2d & 3d mechanical draughtsman (Autocad, Autocad Lt, Inventor)
South Africa
4 REPLIES 4
cadffm
in reply to: MikeKovacik4928
I am missing your info about your ANNOALLVISIBLE setting
Sebastian
cadffm
"The dimensions are working perfectly, no problems there"
If it means
it's working well with annotative dimensions, but not with annotative text,
then it isn't a annoallvisible case.
Sorry, i ignored this the first time of reading.
Same problem with NEW (not copied) items?
In another Layout?
In another file?
Sebastian
MikeKovacik4928
in reply to: cadffm
Hi
I tried in a brand new blank file, starting from scratch, and it worked perfectly.
It must have something to do with the file I am working on at the moment.
Not too sure what might have happened, or how to get it to work in my current file though
Mike Kovacik
cadffm
Open the file by RECOVER
run AUDIT yes
create a new copy by command WBLOCK entire drawing
or copy&paste all content into a new file
or use WBLOCK objects to create a new one
or feel free to share your file.
Sebastian
Technology Administrators
