Annotative Ballooning
micahelXR4VS
micahelXR4VS
Hi All
Is there any way of making balloon referencing annotative in the same way as you can make dimensions annotative so that when you change viewport scales, the balloon changes to suit.
Michael Kovacik
Autocad LT 2025
South Africa
micahelXR4VS
okay
here is what I have found
you can create a multileader object using text and put a frame around the text.
This can be annotative like dimensions.
However the frame is a square.
Is there any way of changing the frame to a circle
Mike Kovacik
tramber
Sure, if you use a block as a content 😉
micahelXR4VS
thanks
cannot find it.
give me more details or screenshots of how to do it
tramber
MLEADERSTYLE
and then in the last tab of an edition of a family 😉
You choose block instead of Mtext
micahelXR4VS
thanks
found it.
Yes that seems to do what I want
