Alternative to SLOPETICK and APPLOAD command in Autocad LT 2017
Hi, is there another way to draw perpendicular slope lines efficiently in Autocad LT 2017?
I tried to follow the instructions from the cadforum: http://www.cadforum.cz/cadforum_en/slope-hatches-batter-lines-in-autocad-tip7965
but APPLOAD is not available in Autocad LT, so i can't load the vlx file SLOPETICK into my version.
Please help with any suggestions?
user181
On the page you link to it says there is also a dynamic block named "Terrain slope" you can download and use. Have you tried using that yet?
Thanks!
I've just downloaded the dynamic block, but I havent worked with dynamic blocks before. so i will see if i can make it  work.
