Adding a extra line to all lines that are manualy typed in
Hi everyone,
When I draw a line in Autocad and I hit *Tab* To manuely type in the distance, it seems to always add a extra small line at the end which adds distance to my line. I always have to double check and delete the extra.
(Say my distance is 12' -1 3/16", Il draw a line, then hit tab and insert the correct numbers to get my distance)
Anyone having this issue? If so is there a fix? I attached a example.
pendean
Community Legend
Community Legend
Why the "tab"?
Correction - I type in the distance then I hit *tab* to go to the angle.
pendean
Community Legend
Community Legend
OK, that makes more sense: tried it as a test using your parameters (start LINE command, click start point, enter distance 12' -1 3/16", TAB, enter 45 angle and click a random distance) and I'm not seeing any extra lines or lengths anywhere.
Sorry but I could not follow your video.
I fixed the issue. it seems the problem was with the fraction of an inch. As an exemple il type in 9'-4-1/2" and it will work with out the extra line.
pendean
Community Legend
Community Legend
9'4-1/2 is how you would type it at the commandline, no spaces.
Emmsleys
Thanks for coming back to the thread to post that you found a suitable workaround.
Did any of the posts in the thread help with the issue?
Please use the Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Thanks for your time.
Sarah Emmsley
Technical Support Specialist
