accidently deleted files in the pattern command. can i restore without reloading
the entire program??
john.vellek
Hi @Anonymous,
It sounds like you are not able to access any hatch patterns. Is this correct? Did you delete the file or just the patterns within AutoCAD?
I suggest that you run a Reset from within AutoCAD  - Select the AutoCAD pulldown-Reset AutoCAD.
Please post your results.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
john.vellek
Hi fritzm54,
I am checking back to see if my post helped you with your problem. Please add a post with your results so other Forum users can benefit.
John Vellek
