Whenever I save a drawing, LT automatically creates a PDF. Searching online, I didn't find anyone else having that problem.
What setting do I change to eliminate the unwanted PDFs?
check AUTOMATICPUB = 0 .
Command: AUTOMATICPUB
Enter new value for AUTOMATICPUB <0>:
Imad Habash
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
It sounds like you have AUTOPUBLISH turned on.
If you want to turn it off open OPTIONS, select the Plot and Publish Tab. On the lower left side you will see a check box.
Thanks for the suggestions, but AUTOPUBLISH is not enabled, either as a command line or in a dialogue box setting.
What method are you using to save the drawings? could you give us a step by step, even better would be a copy of the command line history to see if anything unusual is going on there? Change the variable "macrotrace=1" go through your save routine, then press the F2 key to bring up the command history, right-click in that window and choose the option "copy history" then either paste it into notepad and attach the txt file here or click on the insert code icon when you reply to this forum and paste the results in the dialogue box.
I'm using a "fresh out of the box" setup (no customizations) of LT.
When I create a new drawing, I use the "save as" from the drop-down menu. When I make changes, I click on the "floppy disk" icon. Each time the save process takes place, a PDF is created with the same name as the drawing.
For reference, I've been an ACAD user since the DOS days.
I don't doubt your abilities, but changing macrotrace=1 can give quite a bit more information at the command line, that you don't normally get to see, it's very doubtful that an external source is creating the PDF's, and this is just a way to narrow down the options to find out what is going on, it could be down to a corrupt installation.
Hi @Anonymous,
Does this get corrected if you perform a Reset Settings to Default?
Hi @Anonymous,
Try this link to Reset your Settings.
Thank you for the link.
I understand your desire to return to a baseline as a reference, but after spending time to "personalize" the user-preference settings I'm loathe to go thru that effort again. Are there other methods we can try?
I have a copy of Civil 3D at home and the user preference changes are exactly the same.
HI @Anonymous,
You will have the option to backup your settings during the process. I would like to get back to "factory" so we can see if the problem persists.
