3d Orbit
3d Orbit
lhenderson9L642
Message 1 of 17
3d Orbit
lhenderson9L642
Does anyone know what/all version(s) of AutoCAD the 3dOrbit command is available in?
Accepted solutions (3)
Replies (16)
Message 2 of 17
DarrenP
LT doesn't do 3d Orbit
DarrenP
Message 3 of 17
lhenderson9L642
In saying that, do ALL other Full AutoCAD versions have the 3d Orbit command then?
Message 4 of 17
DarrenP
yes this is a base Autocad command
https://help.autodesk.com/view/ACD/2020/ENU/?guid=GUID-85CE824C-0AF4-4890-8487-ADBC92BF08F1
DarrenP
Message 5 of 17
lhenderson9L642
Thank You! We were just trying to decide whether to bump up to the Full AutoCAD from the LT version. Thank You for your help with this 🙂
Message 6 of 17
steven-g
LT has the -vpoint command for getting around in modelspace, but you have to fill everything in manually so a lot slower.
Message 7 of 17
AutoMarcus
LT doesn't have much 3d at all, unless you count delta z line geometry
Message 8 of 17
tramber
@AutoMarcus , it sounds like you never used the UCS utility at all 😀
Message 9 of 17
AutoMarcus
ha 🤔😄
yes i use it quite a bit, especially in full version 3d
or in LT if aligning a skewed building site plan for convenience
i'm confused now, in LT the ucs just has x and y no?
Message 10 of 17
steven-g
No the ucs has all 3 axis, type 'ucs' followed by enter and look at the prompt, you can rotate the ucs around all 3 axis. You can also highlight the ucs and move it (is that the 4th dimension lol!).
Message 11 of 17
AutoMarcus
well there you go, i should pay more attention to the command line
Thanks Steven
Message 12 of 17
idesignla
yes... SHADEMODE > Hidden .. then go to View Tab > Steering Wheels > hold middle button for Pan, then hold Shift Key.... Orbit in LT
Message 13 of 17
blake.farrow
Observer
Observer
This is the correct answer.
Very good.
Message 14 of 17
ammaron_mcquivey
Observer
Observer
I am aware this thread is old, but I've been using this method of the steering wheels in shademode > hidden, and it seems to break after a while and I was hoping maybe someone could help. Basically after a while it starts to become worse and worse, and the following situations occur one after the other. 1: Selecting an object will no longer center the orbit point and it will orbit a random location nearby. 2: The orbit will eventually seemingly choose a point way outside of the area of the drawing and will cause the drawing to become super far away and disappear immediately. double clicking the scroll wheel will bring the drawing back into view, but will not reset the orbit location. and finally 3: The previous still occurs, but in addition the UCS icon will start to shake erratically and flash between center of screen and bottom left corner. and double clicking the scroll wheel will only bring the drawing back into view after repeated attempts.
Any help with this would be much appreciated, I have tried creating a new view to sort of reset the drawing, but the issues still persist
Message 15 of 17
RSomppi
If you are doing that much 3D work, shouldn't you be using the full version?
Message 16 of 17
ammaron_mcquivey
Observer
Observer
Ideally yes. Unfortunately though while I am currently working a lot with 3D, it's mostly just testing the capability, and trying to develop blocks and tools to help when we do use it sort of thing. We typically don't deal with it very often at the job, and so the company will only pay for the LT version, as that's all we really need. It's only myself and another co-worker who have been pushing the 3D side of things where we can.
Message 17 of 17
pendean
Community Legend
Community Legend
@ammaron_mcquivey LT really doesn't do 3D well at all, just the very hard long and tiresome ways. You are just wasting so much billable time.
Why not invest in SKETCHUP instead if this is a dire business need if full AutoCAD is too expensive for your operation?
