AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
2011LT Block Reference scale
5 REPLIES 5
462 Views, 5 Replies
block reference keeps changing.
5 REPLIES 5
Charles_Shade
pendean
Annotative block by chance?
Or are you jumping between metric and imperial scale DWG files?
in reply to: pendean
yes this was problem. sorry to waste your time. thanks
I have been switching between drawings using metric and Imperial measures by changing the measurement variable from 1 to 0. When working on drawings in Imperial scale and I insert any of the hundreds of blocks I have created in Imperial measures they come into the drawing in a wacky scale. Very. very small. Why? What can I do to prevent this?
Susan
ScottHodges
Just make sure the units of the drawings you are copying from and inserting into are correct. Use the units command to check. Or if you understand scaling turn units to unitless and annotative scaling off like we do and save yourself some hassles
Forma Design Contest
Technology Administrators
