I am not really sure I understand your question or process. However if it
were me, I would create a polygon shapefile using the following method.
1. Create closed polylines
2. Use the Mapexport command
3. Select Polygon Shapefile as export option
4. Select features I wish to export making sure to check the Treat Closed
Polylines as Polygons option
5. Export to shapefile
Another method that works is to generate a polygon topology using the Map
tools in Land Desktop. Then you can export the polygon topology out to a
polygon shapefile also using the Mapexport command.
Tripp Corbin, MCP, CFM, GISP
Vice President, GIS/Mapping
ESRI Authorized Instructor
Keck & Wood, Inc.
www.keckwood.com
Adapx Premier Capturx Digital Pen Reseller
wrote in message news:5911966@discussion.autodesk.com...
I am trying to create a shape file to go into Arcmap with LDD 2005. I have
closed polygon with polylines. When I select the bullet on polylines it
comes in as a dot. I select the bullet on the lines portion and under
options to close it and then it comes in as a polyline, but it is not
closed. Any thoughts?
