"jankowskimd" wrote...
> I don't know a way to permanently imbed an image in a drawing file
Command: INSERTOBJ
will do it.
> When you insert the images, insert each one with the "retain path" box
> unchecked. After that, as long as the image and drawing are in the
> same folder/directly, the image will come in automatically whenever
> the drawing is opened by the client.
It doesn't matter if the path is saved with the image or not, if the image file name is in the same directory as the drawing file, it will be loaded. Same for xrefs.
> I think etransmit will create an executable file that will automatically
> open the drawing and insert the images, but I haven't fooled with it yet.
Sort of, it just finds all the required files and packages them together in a ZIP or EXE file. It doesn't 'open' the drawing on the other end or 'insert' the images.
