Zoom to selected objects
I often use Quick Select to select objects for subsequent manipulation. However, I would like to see which items I'm about to manipulate. It would be very cool to have a routine that takes the list of selected objects and zoom or pan to each object individually. I have searched high & low for an existing lisp or vba routine that would perform this seemingly desirable function. Has anyone created such a function? It would be similar in functionality to the Zoom to button in the TextFind command. --Bill -- William G Voigt (415) 485-3366 voice GIS Analyst (415) 485-3334 fax Dept Public Works 111 Morphew St City of San Rafael San Rafael, CA 94901
Hi Bill, I did this for Land Desktop Alignments, but for AutoCAD things it's probably even easier. All you need is to get the bounding box of the object and then do a zoom window based on the bounding box co-ordinates. -- Laurie Comerford CADApps www.cadapps.com.au "Bill Voigt" wrote in message news:401af392$1_3@newsprd01... > I often use Quick Select to select objects for subsequent manipulation. > However, I would like to see which items I'm about to manipulate. It would > be very cool to have a routine that takes the list of selected objects and > zoom or pan to each object individually. I have searched high & low for an > existing lisp or vba routine that would perform this seemingly desirable > function. > > Has anyone created such a function? > > It would be similar in functionality to the Zoom to button in the TextFind > command. > > --Bill > > -- > William G Voigt (415) 485-3366 voice > GIS Analyst (415) 485-3334 fax > Dept Public Works 111 Morphew St > City of San Rafael San Rafael, CA 94901 > > > >
....Or use AcadApp.ZoomCenter with appropriate object coordinates and zoom factor (say, 30, for example). Regards, Maksim Sestic "Laurie Comerford" wrote in message news:401b1fef_3@newsprd01... > Hi Bill, > > I did this for Land Desktop Alignments, but for AutoCAD things it's probably > even easier. > > All you need is to get the bounding box of the object and then do a zoom > window based on the bounding box co-ordinates. > > -- > > > Laurie Comerford > CADApps > www.cadapps.com.au > > > "Bill Voigt" wrote in message > news:401af392$1_3@newsprd01... > > I often use Quick Select to select objects for subsequent manipulation. > > However, I would like to see which items I'm about to manipulate. It would > > be very cool to have a routine that takes the list of selected objects and > > zoom or pan to each object individually. I have searched high & low for > an > > existing lisp or vba routine that would perform this seemingly desirable > > function. > > > > Has anyone created such a function? > > > > It would be similar in functionality to the Zoom to button in the TextFind > > command. > > > > --Bill > > > > -- > > William G Voigt (415) 485-3366 voice > > GIS Analyst (415) 485-3334 fax > > Dept Public Works 111 Morphew St > > City of San Rafael San Rafael, CA 94901 > > > > > > > > > >
Speed_CAD
Hi...
I hope that this routine help you...
Private Sub ZoomTexto()
Dim sSeleccion As AcadSelectionSet
Dim cSeleccion As AcadSelectionSets
Dim vCodigo As Variant
Dim vEntidad As Variant
Dim codigo(0) As Integer
Dim entidad(0) As Variant
Dim ObjTexto As AcadEntity
Dim n As Integer
n = 1
Dim minP1 As Variant, maxP1 As Variant
Form1.Hide
AppActivate autocadApp.Caption
Set cSeleccion = autocadApp.ActiveDocument.SelectionSets
For Each sSeleccion In cSeleccion
If sSeleccion.Name = "SS" Then
sSeleccion.Delete
Exit For
Next
Set sSeleccion = cSeleccion.Add("SS")
codigo(0) = 0
entidad(0) = "TEXT,MTEXT"
vCodigo = codigo
vEntidad = entidad
sSeleccion.SelectOnScreen vCodigo, vEntidad
For Each ObjTexto In sSeleccion
ObjTexto.GetBoundingBox minP1, maxP1
autocadApp.ZoomWindow minP1, maxP1
If n < sSeleccion.Count Then
autocadApp.ActiveDocument.Utility.Prompt vbCr & "Zoom a: " & ObjTexto.TextString & vbCr
Else
'Salida limpia
autocadApp.ActiveDocument.Utility.Prompt vbCr & "Zoom a: " & ObjTexto.TextString & vbCrLf
autocadApp.ActiveDocument.SendCommand Chr(3)
n = 1 + n
Next ObjTexto
Form1.Show
End Sub
Un saludo de SpeedCAD... 🙂
CHILE
FORO: http://www.hispacad.com/foro
Mauricio Jorquera
I've posted the following routine before. It doesn't specifically address what you've asked for, but there are a couple of aspects that could be useful to what you're doing.
I wrote ShowPoint to use when I'm debugging an application and I want to see where a particular issue is occurring. It will draw a coloured sphere at the specified coordinates and then zoom in incrementally to that point so you can get a perspective of where it is in the entire drawing. It does this by specifying a desired ZoomSize and a number of ZoomSteps to get there. Finally it pops up a message box to pause the action but cleverly drags the box out of the way so you can see what you're looking at.
Const X As Byte = 0, Y As Byte = 1, Z As Byte = 2
Const MAXINT As Integer = 32767
Private Sub ShowPoint(ByVal ptv As Variant, Optional ZoomSize As Double = 7500)
Dim Sphere As Acad3DSolid, I As Single, ViewSize As Double, ViewCtr() As Double, StepCount As Byte
Dim OriginalLayer As AcadLayer
Const SphereRadius As Double = 100, ZoomSteps As Integer = 10
Set OriginalLayer = ThisDrawing.ActiveLayer
ThisDrawing.ActiveLayer = ThisDrawing.Layers.Add("Show")
If UBound(ptv) < Z Then ptv = Coord(ptv(X), ptv(Y), 0)
ThisDrawing.ActiveLayer.LayerOn = True
ThisDrawing.SendCommand "shademode" & vbCr & "O" & vbCr
ViewSize = ThisDrawing.GetVariable("VIEWSIZE") ' Rem Could alternatively Name the original view and restore that when finished.
ViewCtr = UCStoWCS(ThisDrawing.GetVariable("VIEWCTR"))
Set Sphere = ThisDrawing.ModelSpace.AddSphere(ptv, SphereRadius)
Sphere.Color = acMagenta
Sphere.Update
For I = 1 To 100: DoEvents: Next I ' Pause for a moment
For I = ViewSize To ZoomSize Step (ZoomSize - ViewSize) / (ZoomSteps - 1)
ZoomCenter Coord(((Sphere.Centroid(X) * StepCount) + (ViewCtr(X) * (ZoomSteps - StepCount))) / ZoomSteps, ((Sphere.Centroid(Y) * StepCount) + (ViewCtr(Y) * (ZoomSteps - StepCount))) / ZoomSteps, ((Sphere.Centroid(Z) * StepCount) + (ViewCtr(Z) * (ZoomSteps - StepCount))) / ZoomSteps), I
Sphere.Update
StepCount = StepCount + 1 ' We want StepCount to be zero on the first iteration to make the Coord code line above clearer
Next I
ZoomCenter Sphere.Centroid, ZoomSize: Sphere.Update
SendKeys "% m{DOWN 52}{RIGHT 72}{ENTER}" ' Drag the subsequent Message Box into the corner so we can see the point
MsgBox ""
Sphere.Delete
Set Sphere = Nothing
ZoomCenter ViewCtr, ViewSize
ThisDrawing.ActiveLayer = OriginalLayer
ThisDrawing.Layers("Show").Delete
End Sub
Private Function Coord(ByVal ptX As Double, ByVal ptY As Double, Optional ByVal ptZ As Double = MAXINT) As Double()
Dim pt() As Double
If ptZ = MAXINT Then
' 2D
ReDim pt(0 To 1)
pt(X) = ptX: pt(Y) = ptY
Else
' 3D
ReDim pt(0 To 2)
pt(X) = ptX: pt(Y) = ptY: pt(Z) = ptZ
Coord = pt()
End Function
Regards
Wayne Ivory
IT Analyst Programmer
Wespine Industries Pty Ltd
Forgot this companion routine.
Private Function UCStoWCS(ByVal ptv As Variant) As Variant
If UBound(ptv) < 2 Then ReDim Preserve ptv(LBound(ptv) To 2)
UCStoWCS = ThisDrawing.Utility.TranslateCoordinates(ptv, acUCS, acWorld, False)
End Function
Regards
Wayne
