AutoCAD Forum
Zoom Extent shows UCS origin
7 REPLIES 7
Message 1 of 8
752 Views, 7 Replies
I know this has been posted before, but whenever I double click middle mouse button in one of my drawings, it only shows all the objects/lines in the drawing window. (UCS origin is out of frame)
In this drawing (see attached picture) if I zoom extent, it includes the UCS origin. No Xref, all layers on & unlocked, no blocks or groups in the drawing at all, purged, audited, wblock.. I tried everything but it's still including the UCS origin when I click on Zoom extents?
Any help?
7 REPLIES 7
Message 2 of 8
Patchy
Use CTRL key and the letter A
and see what will highlight.
Message 3 of 8
in reply to: Patchy
Nothing gets highlighted close to the UCS  (0, 0)
Message 4 of 8
Patchy
Do you have any xref drawing in this drawing?
Message 5 of 8
in reply to: Patchy
Nope, detached everything..
Message 6 of 8
Found the issue
Message 7 of 8
vinodkl
Hi @Anonymous
Can you let us know how you resolved your issue? So that we can mark that as the answer which would help others when they face a similar problem 🙂
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 8 of 8
in reply to: vinodkl
I deleted all the lines and only drew with layer 0. So only layer 0 and defpoints should be left after purging.
After I purged, there was still one layer left (besides "0" & "defpoints") which made me realise it might have been an "invisible hatch" so I drew a block, hatched it. Selected the hatch and used the select similar command. Lo and behold, there was a few invisible hatches close to the UCS. Deleted it and that fixed the zoom extent issue.
Hope that makes sense, my English isn't great.
