Yet another Invisible viewport
Message 1 of 14
I have viewports that are invisible.  Literally, when I select them using qselect, run the "LIST" command, it shows the following:
Command: LIST
3 found
VIEWPORT Layer: "ST-ANNO-TITL"
Space: Paper space
Layout: ST-001
Invisible
Visual Style: 2D Wireframe
Handle = 34bc6
Status: On and Active
Scale relative to Paper space: 1.0000xp
Annotation Scale: 1:1
View lock is on
center point, X=-0'-6.51" Y= 0'-9.98" Z= 0'-0.00"
width 0'-11.69"
height 0'-5.80"
See how it says "invisible"? How do I make it visible again? I have gone through pages and pages of forums trying to figure this out and have come up with nothing.  No amount of unlocking layers, thawing, turning on, changing color, selecting, etc. has worked.
The best I can come up with is to select them with qselect,delete them, and start over.  This is obviously not ideal.
Thanks!
Replies (13)
Message 2 of 14
pendean
Community Legend
Community Legend
PROPERTIES command?
Post the DWG file.
Message 3 of 14
Attaching the file (no xrefs or anything though, not etransmitted)
Message 4 of 14
pendean
Community Legend
Community Legend
Which layout of the 14 in the file is it?
Message 5 of 14
Sorry, layout PV-001.  Thanks for taking a look. One of the four VPs is selectable, three are not.
Message 6 of 14
pendean
Community Legend
Community Legend
there is no PV-001.
ST-001 looks like this
Message 7 of 14
Whoops, ST-001 is correct.
Our office does Solar Thermal and Photovoltaic (PV) design, I do mostly PV.
Message 8 of 14
pendean
Community Legend
Community Legend
Can you see the image I posted? There is only one viewport and as you can see, it is visible (I am outside of it).
If there is another, show me how to get into it and from where.
Message 9 of 14
There are three other viewports.  The most obvious one is where the Equipment Schedule is, in the upper left.  There is a polyline around the viewport, but if you delete or move it you can see that there is a viewport with no frame.  There is another one in the lower right where the north arrow is.
Message 10 of 14
Did you try doing a quick select of the viewports, then LIST to show that they are invisible (like what I posted in the original)?
Message 11 of 14
pendean
Community Legend
Community Legend
4-very messed up viewports way out there that you can simply delete and recreate instead of spending so much time trying to recover them
When I assign a scale to them they display content outside of their defined edges. I'd just discard them and move on myself.
Message 12 of 14
i agree, deleting and recreating is the way to go.
I'm curious though, how did you even assign a scale to them?
Also, do you have an explanation for the "invisible" aspect that comes up when running LIST?
Message 13 of 14
pendean
Community Legend
Community Legend
>>>...how did you even assign a scale to them?...<<<
PROPERTIES pallette, after I sorted objects by type (viewports in this case).
I don't get distracted or bogged down by what LIST reports: if the objects don't behave the way I want them to I delete and recreate. My clients don't pay me to spend my time bug-testing quirks in software programs, they just want their CAD files out and working well.
Message 14 of 14
Fair enough!
