Anuncios
Yellow Triangle with and Exclamation mark inside.
No aplicable
I have  a project that is showing this Yellow Triangle question mark, but if audit, purge, and burst the drawing is not disappearing and if i want to remover the wall patt or hatch it removed the entire wall. if someone can help me with this issue it will be great.
Ct
0 Me gusta
Responder
Soluciones aceptadas (1)
22.264 Vistas
11 Respuestas
Respuestas (11)
No aplicable
Try clicking the + sign down in the status bar. I believe the ANNOMONITOR is causing those to display.
imadHabash
Annomonitor plus sign will give like what you see  below ,and it's totally different of what you have.for that would you please share with us that symbol and attached here as CAD file ?
Imad Habash
0 Me gusta
No aplicable
no is not i already try this option but still not working
0 Me gusta
No aplicable
0 Me gusta
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
 What version of AutoCAD is installed and what OS are you running? Do you have any Add-ins installed?
This doesn't look like an AutoCAD warning that I have seen before. Does it happen in all drawings or just this one? Can you duplicate the mark on another computer? Please attach a sample file to a post so I can take a look.
John Vellek
0 Me gusta
chriscowgill7373
Solución aceptada
Looks similar to the symbols we get in civil 3d.  is this a vertical such as autocad architecture? If you hover over the symbol do tool tips tell you what it is signifying?
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2022 on Windows 10
RobDraw
Doesn't that indicate that something is not connected?
Rob
0 Me gusta
chriscowgill7373
If you can't post the whole file because of security concerns, perhaps make a copy of the drawing and erase all the content except this area and post that file.
RobDraw
I verified that it does mean that the object is not connected.
Rob
john.vellek
Hi @Anonymous,
This appears to be from AutoCAD Architecture.
What AutoCAD and version are you currently using? DO you have object enablers installed?
John Vellek
0 Me gusta
RobDraw
That triangle is a warning that the element was not contructed properly. I'm pretty sure that not only is an object enabler not necessary but also that @Anonymous is in the same or similar vertical. Otherwise, this warning wouldn't even appear, i.e. it is being recognized as a wall and it is being analyzed as such.
I could be wrong, but that makes sense to me.
Rob
0 Me gusta
