Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
AutoCAD Forum
XYZ Coordinates
2 REPLIES 2
421 Views, 2 Replies
XYZ Coordinates
How can I get the elevation points on this .dwg file into a table so that I can export the XYZ coordinates to a .csv Excel format?
2 REPLIES 2
ara_neresesian
HI
you dont have any points on your drawing.and its flat drawing (except the magenta poly lines )
but you can generate only from magenta poly lines.
try
1-draw points on the contour manually.
2-import it to civil 3d and it can generate point from you 3d contour (magenta  poly lines)
4-you can make a surface by those lines in civil 3d and export the points info
5-ask from surveying department for  raw data (the best way)
6-go to civil 3d forums ,maybe you can find a lisp or vba to generate  points from  poly lines
good luck
Alfred.NESWADBA
Not sure about "elevation points", but if you are referring to the blocks with the blockname = "SRVPNO1" then you should know that all their attribute "ELEV2" are empty:
For creating a table from block-insertions you can use command _DATAEXTRACTION, however, in this case here the ELEV2 will all be listed as empty in the table.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
AutoCAD Inside the Factory
