Anuncios
XREF
XREF
No aplicable
Hi All, im facing a problem with the xref. im using two computer and once of the computer can see the xref but the other cannot. Anyone know why?
0 Me gusta
Responder
Soluciones aceptadas (1)
252 Vistas
1 Respuesta
Respuesta (1)
Vinayv4v
Solución aceptada
Check if the missing item is a nested XREF in one of your loaded Xrefs?
If yes, then you must reload it in that file (parent file). Then try reloading your xref. Check if the problem is solved.
Thanks & Best Regards
Vinay
Cheers,
Vinay Vijayakumaran
