Xref Quit Working
davidsCVYMT
Observer
Xref Quit Working
davidsCVYMT
Observer
Observer
I select attach xref and the box opens to select a file.  I select the file and then click open.  Once done the autocad seems as if it has frozen.  If I hit the ESC key the cross hairs come back.  If I hit the enter key the reference file attaches, however the dialog box never showed itself.  The FILEDIA is set to 1 and the CMDDIA is also set to one.  i have closed autocad and shut down the computer and still same results.  please help.  thanks.
0 Me gusta
Responder
340 Vistas
8 Respuestas
Respuestas (8)
imadHabash
referencing to your AutoCAD version please install the last service packs and updates .
Imad Habash
0 Me gusta
davidsCVYMT
Observer
Observer
All updates and service packs have been installed. The only other option I have is to install autocad 2018. Thanks.
0 Me gusta
imadHabash
please ... ( as a try ) try to draw a simple rectangle in a empty dwg and attached it as an xref in another new dwg file and tell us if it's happend again ?
Imad Habash
0 Me gusta
davidsCVYMT
Observer
Observer
Same thing happens. Thanks.
0 Me gusta
pendean
Community Legend
Community Legend
Your XREF palette is off-screen (or on the second screen you used to use). Get it back these ways https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Palett...
0 Me gusta
davidsCVYMT
Observer
Observer
The palette is not the issue. The palette shows up. It is the dialog box after which shows the insertion point, scale, attach and overlay options.
0 Me gusta
No aplicable
Do you have multiple monitors? If so, the problem could indeed be that the 2nd dialog is off screen. You could try the steps Dean mentioned above, or disconnect the 2nd monitor and see if the dialog reappears on the main display. I have this happen when I try to use my laptop with an external monitor, and set the external as the main display.
0 Me gusta
davidsCVYMT
Observer
Observer
I disconnected the lap top from all monitors and still same problem.
0 Me gusta
