02:25 PM
I have two drawings that are supposed to have the same origin. I drew perpendicular xlines in both at the origin (0,0) (2-D) (not on the 0 layer) and saved each. The I xref one into the other and vice versa. xrefing in one direction, the lines fall on top of each other. The other, they do not fall on top of each other.
I noticed that the direction vectors of the xlines in one of the drawings is odd and I wonder if this is contributing to the problem. ... see the attached screen copy of the xline properties. What is this direction vector? It isn't parallel or perpendicular to the xline. Could it be contributing to the xref alignment issue?
