XREF - Macro to change file location
Originally posted this in LT by mistake:
We have several files which were moved into a PDM Vault from a network folder. Due to file references in some of those files, some of the company logos are not pointing to the new location in the Vault, and instead it is pointing back to the network folder.
Each of these logos is named COMPANY.bmp, and they are all pointing in the same original location, //omega/logos/COMPANY.bmp
This is causing issues when we update these files because we cannot check-in the files into the Vault due to the external reference on the network.
I would like to create a macro which will update the XREF (Named "COMPANY") from the old file location, to the new file location //Vault/Library/COMPANY.bmp
I could not do an action record to replace this reference due to the XREF.
Marc
kcobabe
Use the Autodesk Reference Manager.  It's been available for sometime.  I have 2012-2015 installed on my computer and it resides in every one of them.
R10 - 2020 ACAD
2008 - 2020 Civil 3D
2014 - 2020 Plant 3D
2014 - 2020 Revit
V8i - V8i SS4 Microstation
Infraworks
2018-2020 Inventor
2020 Navisworks
