xref hatching interferes with object selection
thomas_schluesselberger
Message 1 of 9
Hello!
I have a problem:
When i want to select objects to stretch via a selection window, it often happens that it interferes with one of the xrefs.
The xrefs often have hatchings or other objets which disturbs while making the first point of a selection window.
I have attached a video in which I want to stretch the line or move the circles. I can only use the selection window if I either don't make the first point within the hatching, or I make sure that I click between the hatching lines.
Replies (8)
Message 2 of 9
cadffm
if you are using the implied windowing (PICKAUTO bit1), Acad detects an object in your APERTURE, so the object-PICK method is active.
If you would tell Acad that you want to use a Window- or Cross selection, it would work as you need.
Try it: When Acad ask for Object selection, type-in W<enter> and try your window selection again.
Sebastian
Message 3 of 9
Hi!
Thanks, so this fixes my problem when using move or other commands where i select the wanted objects entirely.
But it does not work for an stretch command. Because when streching i only want to select the end of the line which should get streched and with this method objects only get selected when they are selected completely.
Or is there a fix for this?
Message 4 of 9
cadffm
learn about object selection methods
object snaps
view and ucs handling
These are basic skills which are in use in all tasks.
Stretch just some points of an object need a cross or crosspolygon selection,
the short is C or CP
[F1]
SELECT (Command)
Ignore the command, but the Object selection methods are explained there.
Sebastian
Message 5 of 9
It's crazy that i'm using AUTOCAD five years now and never heard of this selection methods. 🙂
I always just used the normal object selection the individual commands give you.
Thanks a lot!
Message 6 of 9
cadffm
Some commands offering a <Pick>selection only, but for the most you can use all object selections you like.
FENCE
WindowPolygon
Group (if you are using groups)
Last
Previous
And SUBobject selection
A lot methods.
Sebastian
Message 7 of 9
steve_MonkeyFlow
Try setting the OSNAPHATCH variable to 0.
AutoCAD will then ignore hatches when snapping - remember to switch back to 1 when you need to snap to hatches!
www.monkeyflow.co.uk
Message 8 of 9
Thanks for you suggestion, but the snapping wasn't the problem.
Message 9 of 9
Kent1Cooper
FENCE
WindowPolygon
Last
Previous
A lot methods.
[Except that for this topic's STRETCH command specifically, either Crossing or Crossing-Polygon selection is required.  Or Lasso, but you can't type in an initial for that to avoid its grabbing a Hatch pattern that you must pick in the middle of, the way you can type in C or CP.]
Kent Cooper, AIA
