xref command is not working in Autocad 2019
xref command stop working after 1 week of Autocad 2019 installation, there is no response when with the xref command.
Alfred.NESWADBA
Make sure you have the XRef palette not minimized, or docked + minimized.
If you have not done any customization's you might reset the AutoCAD profile to default so the XRef palette starts at the default position.
Details about resetting the AutoCAD profile: >>>click<<<
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
hi Alfred,
i did all that but still not working.
pendean
Community Legend
Community Legend
Did you really reset AutoCAD and nothing helped? Or did you miss the link, here it is again https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to...
hi,
my windows 10 is not showing reset setting to default so i had to do it manually following the instructions but still not working
vinodkl
I guess the xref window might be out of view.
here is how you can get it back: Click here
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
pendean
Community Legend
Community Legend
You probably need to do this then if you cannot move the missing palette back into view or CLASSICXREF command also does not work https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/Recommen...
