Xref block Units
Xref block Units
aaroNVK33B
Message 1 of 8
Xref block Units
aaroNVK33B
Every time when I open a new drawing and xref my title block - the dialogue box shows this units and factors - this factors and units cannot edited as well. I use metric system and both of my drawings are in metric units. Is there anything that I'm not fixing? Because of this - most of my drawings are out of scale.
I'm currently using AutoCAD Architecture 2024 - English as AutoCAD.
Replies (7)
Message 2 of 8
cadffm
your INSUNITS setting in xref Titleblock-DWG is set to?
Sebastian
Message 3 of 8
pendean
Community Legend
Community Legend
Share your titleblock DWG file and a sample top-file DWG file with that XREFfed in it here: ensure the problem exists, then let everyone here help you fix your DWG files moving forward.
Message 4 of 8
aaroNVK33B
Bot the INSUNIST is set to 1.
Message 5 of 8
cadffm
@aaroNVK33B wrote:
When I changed the INSUNITS from Xref to 1
and my working drawings to 4 and it works.
So you drawed your Titel/frame in Inches, but your working drawings are in Millimeter?
Unusual.
Sebastian
Message 6 of 8
aaroNVK33B
Please see attached Test Files of the issue that I'm facing.
Message 7 of 8
aaroNVK33B
Please check attached my files - Working drawing labelled as test files while the drawings that i want to xref is the xref.
I'm using the xref as a title block.
Message 8 of 8
cadffm
1. In Xref file, you changed insunits from 4 to 1,
but the title/frame is drawed in Millimeter, insunits 4 is correct!
Change it back to 4
2. Your drawing file.. Hey? That's also drawn in Millimeter, or not?
If Millimeter is right, change insunits to 4 (for Millimeter).
3. Still in your drawing file, select your External Reference
     and change XYZ-Scale to 1
Sebastian
