xref binding an image
strictlyvintagesurf
strictlyvintagesurf
hi guys
I need some info can you bind an image in autocad so that when the drawing is complete you can send it to someone without the image missing ?
thanks
0 Me gusta
Responder
Soluciones aceptadas (1)
10.833 Vistas
4 Respuestas
Respuestas (4)
ennujozlagam
hello, you cannot bind image . if you want you can try this process it's already embedded into into a drawing no need to worry about image attached and send to other consultant. thanks
0 Me gusta
cadffm
The right way is to attach the image with relative path (or non, if the image is in tge same folder). Send your DWG and the imagefile.
The perfect way: Use command etransmit for all external stuff like fonts images other xrefs plotstyletable..
The only way to paste an image as content to dwg is to insert it as embedded OLE object.
But i not prefer to merge raster data with your well vector datas in your dwg.
So: Attached img bind directly is not possible.
Sebastian
scot-65
Solución aceptada
This subject matter has been discussed many times in this forum.
Hint: Place image into clipboard then PASTESPEC - accept the prompts.
Embed, not bind.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
0 Me gusta
lokojaboy
Observer
Observer
Just in case someone else needs the info, there is a way! (two actually)
1. PASTESPEC command in AutoCAD (as mentioned before) and after CTRL-A and CTRL-C of the image in MS Paint
2. CTRL-V after CTRL-A and CTRL-C of the image in MS Paint (Okay pop-up window)
File must be less than 1MB
The prescribed file size requirement is mentioned here https://www.cadlinecommunity.co.uk/hc/en-us/articles/360016935937-AutoCAD-Tip-Embed-Images-into-Auto...
0 Me gusta
