xref annotation become bigger
noli1057
noli1057
To the expert here, anyone know what causing this? All external reference text or annotation become bigger. I tried to turn on and off the annotation scale but didn't work. I appreciate you immediate help about this issue. - Thanks.
imadHabash
I suggest to look in the bottom-right corner of the AutoCAD status bar and verify the annotation scale is correct. Also you may need to check the value for ANNOAUTOSCALE (System Variable).
Imad Habash
noli1057
 imadHabash, Thanks to your response. It works in the Model Space, but how about in the paper space - it didn't change automatically. Any option please. - Thanks again.
imadHabash
Check if your VP rectangle dimensions have the right unit size that meet your model element units.( Meter vs Meter and so on )
Imad Habash
vinodkl
Hello @noli1057
Please share the drawing so we can test it from our end.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
CGBenner
@noli1057
Did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Chris Benner
