XCLIP References
XCLIP References
Message 1 of 11
XCLIP References
I cannot see my XREF once I create a clipping boundary upon it. Invert clip command does not solve the situation. I have looked all over google, but I cannot come across any answer. Has anyone else come across this situation, if so have you found a solution and what is it ?
Replies (10)
Message 2 of 11
imadHabash
Things to check :
  • if any updates needed for your AutoCAD . >> Click <<
  • if disabling hardware acceleration help ( GRAPHICSCONFIG command ).
  • if you make a new trial CAD drawing and for a simple shape , any changes ?
Imad Habash
Message 3 of 11
Alfred.NESWADBA
what happens when you open the XRef manager, right-click this reference and use "Reload"?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 4 of 11
This doesn't make any difference, the xref itself reloads but still doesn't show via the clipping boundary. Thanks
Message 5 of 11
Alfred.NESWADBA
does removing the clip boundary make the XRef visible?
Which version of AutoCAD do you have? (command _ABOUT and screenshot might help)
- alfred -
Alfred NESWADBA
Message 6 of 11
Ahh, yes. It work in a new and fresh file. What does this mean for my existing files though ? It looks like the file itself is corrupted so much to not allow me to use the xclip command properly....
Message 7 of 11
Yes
Message 8 of 11
imadHabash
Good ... try to attache please the same xref to a new CAD file and xclip it , any changes ?
Imad Habash
Message 9 of 11
That works...
Message 10 of 11
imadHabash
Great... that means there is something in a certain CAD drawing . if you can attache your drawing ( with the problem ) and the xref to see and check , it will be a great chance ?
Imad Habash
Message 11 of 11
Thanks for your help. Much appreciated.
