x-ref's still unreferenced after file path is updated
KellyDickinson
KellyDickinson
Hello all,
I am having an issue with xrefs attached to drawings I received from an outside source. I get the xref manager message when opening said drawings, go in and update the file path, but after doing so, they are still "unreferenced". Any ideas? Thanks for any help.
0 Me gusta
Responder
794 Vistas
1 Respuesta
Respuesta (1)
Alfred.NESWADBA
"Unreferenced" does not mean that the path is incorrect, it meanst this XRef is not used within your drawing.
Sample: you start command XRef and place an external DWG to your modelspace (looks like a block then), next step you delete this object from modelspace. Now AutoCAD is in the situation that it knows there is a pointer to the external DWG-file, but it is not used any more in the drawing (as you deleted the insertion) ... that is "unreferenced".
In that case you can right click the file in the XRef-manager ==> Detach.
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
