Wrong dimensions between model space and layout
Message 1 of 8
I'm facing an issue with dimensions in the layout space. I've drawn a line of 100mm in lenght in the model space and I used Linear dimension on it, the lenght is good with 100mm. Now, in the layout space, I create a viewport with a scale of 1:1, my line is displayed with the dimension of 100mm, then, I use again the linear dimension and I get a dimension of 99.77mm.
I checked the viewport settings, dimension properties, and nothing seems wrong.
Any ideas ?
Thank you !
Replies (7)
Message 2 of 8
pendean
Community Legend
Community Legend
Is your viewport set to a scale?
Are you snapping to the endpoints of that line with both dimensions?
DIMASSOC variable, what is it set to?
Message 3 of 8
beyoungjr
Just post the drawing and we will see what's wrong.
Blaine Young
Senior Engineering Technician, US Army
Message 4 of 8
Thank you for your answers Dean and blyoung,
This is the property panel from the viewport:
I selected the snap mode "Endpoint" to avoid any error when creating the dimension.
The DIMASSOC variable is set to "2"
I attached the dwg to this post.
Message 5 of 8
pendean
Community Legend
Community Legend
Increase DIMRND variable to more than two decimal points accuracy (I set it to 1/10000) and your modelspace dimension will match your paperspace dimension of 99.77
Your line is not exactly 100 long.
Message 6 of 8
sthompson1021
Click into MS and change your view from custom to top and then reset your VP scale to 1:5 and the dimension is right.
Message 7 of 8
jackshield
GOOD CATCH!
Message 8 of 8
Thanks sthompson1021, problem solved !
And thank you all for your help !
