Write Vertical Curve Data near to curve
arshadmirza786
arshadmirza786
I Hope one should help to write a lisp for vertical curve data in a table near to each curve with curve sr #
0 Me gusta
Responder
544 Vistas
9 Respuestas
Respuestas (9)
Pointdump
Hi Arshad,
No need for LISP. You can EXPLODE that Polyline and use DATAEXTRACTION to create a Table, Excel File, or CSV File. CSV File Attached.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
0 Me gusta
arshadmirza786
Thank you for this suggestion
I think we write the +ve & -ve grade too and PVI etc for vertical curves
0 Me gusta
Pointdump
Arshad,
"...+ve & -ve grade too and PVI etc..."
Then you'll need to do this with Civil 3D. There you can label each vertical curve.
Dave
Dave Stoll
Las Vegas, Nevada
0 Me gusta
arshadmirza786
How to convert this pline in C3D vertical curve profile ???
0 Me gusta
Pointdump
Arshad,
In civil 3D you'll need a Surface and an Alignment before you can create a Vertical Profile. So you might be better off in Vanila AutoCAD using a Table at each curve, like you originally asked. About LISP's I know very little. You can check the >>>Autodesk App Store<<<.
Dave
Dave Stoll
Las Vegas, Nevada
0 Me gusta
arshadmirza786
Yes I have only this pline to write the vertical curve data nothing more
0 Me gusta
arshadmirza786
As per my search Nothing about " CURVE " at this store
0 Me gusta
arshadmirza786
# dlanorh May I disturb you, I hope you will help me for this topic as usual
Now the problem is for Vertical Curve and following in formation or more be added to a curve
VERTICAL CURVE #
BIGNNING OF VERTICAL CURVE STATION = BVCS
BIGNNING OF VERTICAL CURVE ELEVATION = BVCE
= PVI STA
= PVI ELEV
= K
= LVC
END OF VERTICAL CURVE STATION = BVCS
END OF VERTICAL CURVE ELEVATION = BVCE
GRADE UP TO BEGINNING OF CURVE = +VE% OR -VE%
GRADE AFTER END OF CURVE = +VE% OR -VE%
For more guide lines pls refer to
https://www.mathalino.com/reviewer/surveying-and-transportation-engineering/parabolic-curve
I hope you will manage some piece of time for me / in this regard
0 Me gusta
arshadmirza786
0 Me gusta
