wrapping small circles around a larger circle
Hi Folks - looking for some advice on how to design something in AutoCAD. I've only ever played with AutoCAD before but I've recently gotten into the CNC world and need the exactness of AutoCAD to cut some stuff. So far I'm doing ok but I'm stuck with trying to create a large diameter circle (12") with 16 3/4" circles centered evenly spaced along the larger circle (I can create the circles just not be able to get the small circles to arrange themselves evenly along the larger circle). Know what you get when you google anything about wrapping around a circle? How to wrap text 😞 Thanks for the assist!
Slawomir_
Correct me if I'm wrong:
1. Draw one 12" circle and one 3/4" and use ARRAY command.
2. Do You want to wrap text? Try changing text to mtext by using TXT2MTXTX command and than wrap it.
imadHabash
ARRAY command line is your need.
i feel that you still need more info.. so don't hesitate to ask please 🙂
Imad Habash
