Working in 2D, how to prevent lines having "Z" values.
Message 1 of 18
I work in 2D and NEVER use 3D, but for some reason I cannot rid the "Z" value on these lines inside the CAD file. Yes it's only with a certain account that I have this trouble with, no other acccounts/drawings have this issue. I'm just so done with having to "flatten" all of the lines every time just to fillet or connect them. Isn't there an easy setting to prevent this? Again, I'm not in 3D, nor working with a 3D file, doesn't matter if it's a new line I'm drawing or not CAD will free-willingly make it a line in the "Z" axis without me knowing until I'm trying to fillet or whatever.
How can I prevent this "Z" axis 3D problem in 2D? THANK YOU SO MUCH IN ADVANCE!
Replies (17)
Message 2 of 18
Patchy
OSNAPZ setting
Message 3 of 18
Thank you so much! I tried that and it showed the previous OSNAPZ value as <0> and so I re-entered the same value as "0", I will see if my problem persists. THANK YOU AGAIN!!
Message 4 of 18
cadffm
We can not know how YOU do it without knowing your data and settings.
Some points will draw a line on Z/=0
Current ucs is not on z=0
If you have existing objects with z/=0 and you are using objectsnaps for create, copy or move
Read about OSNAPZ
You ever working in a 3D room, today there isn't a variable to force 2D.
Sebastian
Message 5 of 18
Patchy
I think OSNAPZ setting on 1 will always draw o elevation
Message 6 of 18
Ok! I will try that too!! Thank you so much, I greatly appreciate it!!
Message 7 of 18
Kent1Cooper
@Anonymous, don't rely on what people think, or try different values to see what works -- just read about OSNAPZ in Help, which will tell you all about it.
Kent Cooper, AIA
Message 8 of 18
Thank you!
Message 9 of 18
gotphish001
You can toggle the replace z value button on as seen in image. If that is set to zero and checked even if you are snapping to something that is say 3' up on the Z axis it will still place it at 0 elevation.
Nick DiPietro
Cad Manager/Monkey
Message 10 of 18
Thank you so much!! This helps a lot!!
Message 11 of 18
I'm still having the same issues, I'm going to try the help center and read through what I can, I doubt it will be anymore helpful than what I've already researched. Values of 1 and 0 have not made a difference, I've even turned off the 3D toggle and snap setting hoping that would change things and it has not.
I greatly appreciate everyone's input, you've been great!!
I will let you know what I find if a solution falls into my lap.
Happy CAD'ing!!
Message 12 of 18
j.palmeL29YX
Is your Elevation really = 0? Because, what I read above ("OSNAPZ setting on 1 will always draw o elevation") is not correct. OSNAPZ=1 doesn't draw at Z=0, but it ignores the Z value of a snapped coordinate and draws at Z=Elevation.
cadder
Jürgen Palme
Message 13 of 18
Yes, I've tried both and still get the same Z value happening, thus I could not fillet two lines to connect because they're in different "planes" or axis's. It did not work for me, it may work for others which is great! I may have something else going on with my CAD or another user in this particular account. It does happen with other files of mine, but not as consistent as this specific account files. I may have to reach out to the other end user to see what their values are set at. If they're working in 3D then it would answer my problem. Although, my lines shouldn't be drawing in the Z axis if my 3D settings and snaps are off.
Currently, I'm still "flattening" all of the lines to then move forward working in the file. Although, this is very time consuming, it is working for now.
Message 14 of 18
faragello
I have same this problem !!!!
Message 15 of 18
j.palmeL29YX
Please describe your problem in more detail. And attach a dwg so we can see what you have and what you want to do (or what you expect to get).
cadder
Jürgen Palme
Message 16 of 18
CHOWARDYKWMG
Community Visitor
Community Visitor
I am having this problem. My osnapz was set to 1. I have figured out why this is happening. I am using downloaded cad dwgs from Hoffman and Allen Bradley. They offer 2 and 3d files. They must be using the 3d models to make the 2d and they are at different z depths. I copy and paste what I need into my file. The osnap does not always land at z=0. I am going to try using 0,0,0 when I insert using ctrl v.
Message 17 of 18
Kent1Cooper
@CHOWARDYKWMG wrote:
.... I am using downloaded cad dwgs from Hoffman and Allen Bradley. They offer 2 and 3d files. They must be using the 3d models to make the 2d and they are at different z depths. ....
[I suggest opening those drawings after downloading, and using FLATTEN in them before using them in your drawings.]
Kent Cooper, AIA
Message 18 of 18
CHOWARDYKWMG
Community Visitor
Community Visitor
In the future I will. I tried using flatten on my drawing with the inserted equipment. Not much help. It is nice to know what is causing the problem.
|Thanks for the advice.
