Wipeouts Are Not Plotting Using DWG to PDF
I have a drawing in which the wipeouts are not plotting when I use DWG to PDF. The wipeouts work in model space and are showing up properly in paper space. But when I plot using DWG to PDF, the wipeouts don't work.
I have used wipeouts before on this computer and they have worked. So I am not sure what it is about this drawing that is causing them to not work.
I have attached a pared-down version of the drawing to this message.
As a note, I have WIPEOUTFRAME set to 0, and the wipeouts are on the lower panels, grouped with each panel.
Thank you
