AutoCAD Forum
Wipeout on 3D solid
10 REPLIES 10
Message 1 of 11
nG!Hebus
1626 Views, 10 Replies
Wipeout on 3D solid
I need solution for wipeout command on 3D solid.
Here screen to explain what i want:
on 3D real i don't want to see tube like second screen.
Thx for your help.
HF on Autocad 😉
_________________________________________________________________________________
Apprendre chaque jour est une chance que certains oublient de saisir !
10 REPLIES 10
Message 2 of 11
Alfred.NESWADBA
in reply to: nG!Hebus
wipeouts only work for 2D and draworder, they are not a replacement for "make 3D objects transparent".
But exactly that is what I would do: "make the 3D-objects transparent", so you can see through to the inner part for visual styles that support transparent materials, for other visual styles you can't see through ...
  • or you can change the material
  • or you can create 2 objects, teh outer one and the inner one and switch layers to decide which of them to see
  • (more ideas might come up here ...)
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 11
nG!Hebus
in reply to: Alfred.NESWADBA
Ok but why it's ok on second screen and not ok on first?
I did box with the wipeout command. it's working on wired.
Can you show how you make 3D transparent, it can replace 3D solid?
you must cut solid for insert transparent 3D solid? cause i don't want to replace or cut my tube, only don't show it when i insert my block on it.
Message 4 of 11
Alfred.NESWADBA
Where on the second screen is a wipeout? Can you upload the dwg-file please?
Start command _MATBROWSEROPEN and select a transparent material like glas, assign it to the object you'd like to be transparent.
Yep, a material is valid for the whole object (you might assign it to faces of a solid, but that can't be handled in a well structured way).
Than wouldn't it be easier to just change the visual style to "Wireframe" or "2D-Wireframe" (you can work in two windows, one shared and the other one in wireframe mode. That should work well if you just need it to find the object snap point.
(this brings all into a new light, I have not understood your initial post in that way, I thought you need that in that way to be plotted for documentation)
- alfred -
Alfred NESWADBA
Message 5 of 11
imadHabash
>> Can you show how you make 3D transparent, it can replace 3D solid? <<
by proprieties dialog Ctrl+1 select your item then type Ctrl+1(see below image) Transparency value (0-90).
Message 6 of 11
nG!Hebus
in reply to: imadHabash
i join model for your test.
for don't see wipeout i force them in 0,0,0 (black color).
THx for help
Message 7 of 11
Alfred.NESWADBA
wow, never have seen wipeouts used in that way 😉
Looking to it in detail (to the 2D-Wireframe style) there are also display issues of that object as the wipouts also clip the outer part of the cylinder:
Using materials could be that result (whithout having split the outer cylinder):
HTH, - alfred -
Alfred NESWADBA
Message 8 of 11
rculp
Not sure what you're attempting to accomplish, but in most cases the valve breaks the line in which it is inserted with either a welded joint, a flange or a coupling, all of which need to be indicated on the drawing.  If you're just trying to make it easier to model so you don't have to adjust the pipe when the valve moves, I think you're out of luck as most of the work-arounds discussed so far will fail to produce the right view when you go to drawing production.
If you leave the pipe cylinders alone (no slicing) they are quite easy to change length by just grabbing a grip and dragging.
But hey, that's just me.
Randall Culp
Civil-Structural Design Technician
(aka CADaver)
Message 9 of 11
nG!Hebus
in reply to: rculp
I know i work in this way actually but, i just ask for see if anyone have solution. So i continu like this for moment but i seek solution, if i have i become to explain how we can do it 😉
PS : Sorry for my english speaking.
Message 10 of 11
rculp
It appears as if you are trying to blockout the pipe as you move the valve in order to make it appear as though there is a break in the pipe at the valve.  While a wipeout works for that in 2D, you are out of luck for 3D without some very heavy programming.
Your solutions are:
1. Break the pipe at the valve, leaving the cylinders as cylinders so they are easy to grip drag the lengths.
2. Invest in a real pipe modeling application like Plant 3D that will automate (somewhat) the control of valve locations.
3. Have someone write an alternative to Plant 3D (that will be expensive)
Randall Culp
(aka CADaver)
Message 11 of 11
O_Eckmann
Wipeout is out because can't be used in 3D model.
Only solution I can think is to use a new block embending your original block + a cylinder just larger. After inserting your block, you explode it and use cylinder to make a substraction to the pipe. With SOLIDHIST at 1 and Ctrl pressed when selecting around your block, you can chose Extrusion and your block to move them together. Perhaps, it's what you're already doing.
Here is link for Screencast : http://autode.sk/2uIZfnc
Olivier
Olivier Eckmann
”Boost
