>> why it's ok on second screen and not ok on first?
Where on the second screen is a wipeout? Can you upload the dwg-file please?
>> Can you show how you make 3D transparent
Start command _MATBROWSEROPEN and select a transparent material like glas, assign it to the object you'd like to be transparent.
>> you must cut solid for insert transparent 3D solid?
Yep, a material is valid for the whole object (you might assign it to faces of a solid, but that can't be handled in a well structured way).
>> cause i don't want to replace or cut my tube, only don't show it when i insert my block on it.
Than wouldn't it be easier to just change the visual style to "Wireframe" or "2D-Wireframe" (you can work in two windows, one shared and the other one in wireframe mode. That should work well if you just need it to find the object snap point.
(this brings all into a new light, I have not understood your initial post in that way, I thought you need that in that way to be plotted for documentation)
- alfred -
Alfred NESWADBA
www.ish-solutions.at ...
blog.ish-solutions.at ...
LinkedIn ...
CDay 2025------------------------------------------------------------------------------------
(not an Autodesk consultant)
