wipeout command → Frame option → what is display but not plot ?
Message 1 of 15
I do not see the difference between " display but not plot " and "ON - frames are displayed and plotted"  because in both cases frames are plotted. Why so ?  You can check my two dwg file "wipeoutframe 1 " and " wipeoutframe 2"
Replies (14)
Message 2 of 15
ВeekeeCZ
A quick try... seems working well.
Message 3 of 15
what is this ?
Message 4 of 15
tim_crouse
Here are my Wipeout Tips I have acquired over the years
Best Regards
-Tim C.
Message 5 of 15
please again describe exactly your answer, I m not understanding at all
Message 6 of 15
cadffm
>>"I do not see the difference between "display but not plot" and "ON - frames are displayed and plotted""
For usual and how it works on our workstation with your files too:
"display but not plot" = You can see it on monitor, but not in your plot result (paper,image or pdf..)
"on" = you can see it on monitor and in your plot result as well.
>""because in both cases frames are plotted. Why so ?"
I am 99% sure it is not the case. Are you sure you didn't made mistake in your test?
>>"You can check my two dwg file "wipeoutframe 1 " and " wipeoutframe 2"
"wipeoutframe 1.dwg"
Sysvar "wipeoutframe" is set to 2 => "display BUT NOT plot"
And it works, see Z9E3zK5E attachments
"wipeoutframe 2.dwg"
Sysvar "wipeoutframe" is set to 1 => "display AND plot"
You asked Z9E3zK5E "what is this ?"
Answer: This is the plot result of your drawings!
The one with, the other one without wipeoutframes. Just open your attached dwg files, run plot, that's all.
Test it again, i am sure it will works.
The only problem i see are the poorly titled dwg files
wipeoutframe 2 for the wipeoutframe 1 file
wipeoutframe 1 for the wipeoutframe 2 file
that's why i guess you got bogged down with the test
Sebastian
Message 7 of 15
"display but not plot" = I can see it on monitor as well as in my plot result (paper space ). ...that is the problem.!
Message 8 of 15
cadffm
>>"Test it again, i am sure it will works."
>>""display but not plot" = I can see it on monitor as well as in my plot result (paper space ). ...that is the problem.!"
Test it again with my attached file, just open the file and while in Model tab, Command: PLOT<enter>[OK]
if it is visible, share your PDF and share a screenshot of dialog, command: ABOUT
Sebastian
Message 9 of 15
As you said,
→ type command " plot ",enter and command " About " ,enter
→ share a screenshot of these two dialog box
     I have sent you in the attached file
     But I do not know how to share pdf from autocad
Message 10 of 15
cadffm
>>"But I do not know how to share pdf from autocad"
?what You uploaded two PNG files, for PDF it i the same way.
>>just open the file
I think you used the PLOT command one ore more time in the past,
so it's nothing new for you.
Open the file,
Type-in PLOT<press enter>
press [OK]
I am confused about your last answer
Sebastian
Message 11 of 15
Yes, now I see no frame display when I see it in pdf format. I have sent you pdf attachment.
But is this WIPEOUTFRAME 2 setting only applied to pdf format ?
Message 12 of 15
pendean
Community Legend
Community Legend
@Anonymous Your screenshot is doing exactly what HELP says it is supposed to be doing (see below).
If I may ask: what did you think needed to happen in the PDF?
Message 13 of 15
cadffm
Good to hear (and see), seems to work as it should
No, it doesn't matter which output is used - digital or paper, all the same.
If another printer shows another result, there is something special with this printer-driver or settings.
Start PLOT, Select another printer, press [Preview] - The frame should'nt appears while wipeoutframe is set to 0 or 2
Sebastian
Message 14 of 15
I see WIPEOUTFRAME 0 setting have effect on paper space but WIPEOUTFRAME 2 setting does not make any difference in paper space.
Message 15 of 15
cadffm
It seems your AutoCAD is working as it is all explained to you here
and exactly as it says in the help.
I'm pleased.
The only question i have, may i ask whyyou posted a wrong statements first? ""because in both cases frames are plotted. Why so ? ""
In your other thread i see you have a hard time with documentation and help from others, so i let it be how it is now.
Paperspace is not a plot, it is a space to setup a drawing (drawing frame, legend, stamp ...).
Near to a plot ist the Plot[Preview], but it is also just a try to give you an idea of how it would come out afterwards,
must not 100% identical with you plot (paper & digital files like jpeg or PDF).
Sebastian
